Conversation Improvements by Xon 2.5.1
XF 2.0 / 2.1 / 2.2 / 2.3 Conversation Improvements by Xon 2.5.1
Titre du sujet Titre du sujet Conversation Improvements by Xon 2.5.1
Réponses Réponses 16
Affichages Affichages 1 079
A collection of improvements to the XenForo Conversation system.
For large forums, please see the "Installing for large forums" section
Uninstalling removes all data!
Search Index however will require a full rebuild to delete the old data!
Features
  • Adds conversation search, with options to search by recipient.
  • New Conversation Permissions
  • Conversation Message Edit history
  • Conversation Title Edit history
  • Allow conversations with no-one (default off)
Users must be a member of the conversation to see the conversation in search results.
Does not permit moderators/administrators to see another person's conversations in search results.
Adds each conversation, and conversation message to the XenForo Search store (MySQL or Elastic Search), which may result in a larger search index.
Just takes away a user's "reply" button, no banners.
The reply limit is for the entire conversation, but the limit is per user group. Consider when User A & User B are members of a conversation.
User A can have a reply limit of 5. User B can have a reply limit of 10.
Once the conversation has >5 replies, User A can no longer post. Once the conversation has >10 replies, User A and User B can no longer post
Conversation Message Edit History
Adds edit history for conversation messages.
Conversation Title Edit History
Adds edit history for conversation's title, and implements a new moderator permission "Manage Conversations by anyone" to allow non-conversation starters to edit a conversation.
A global option to allow users to send conversations to just themselves.
Known Issues
  • Edit History does not respect/implement any silent editing window.
  • This add-on likely will require a higher memory limit (ie <256mb isn't going to cut it) due to extra search results.
For large forums, please try manually adding all the columns in a single step.
This took upto 5 minutes for 1.3 million conversation messages (compressed).
ALTER TABLE `xf_conversation_message`
ADD COLUMN `edit_count` int not null default 0,
ADD COLUMN `last_edit_date` int not null default 0,
ADD COLUMN `last_edit_user_id` int not null default 0;
ALTER TABLE `xf_conversation_master`
Permissions
  • Can Reply to Conversation. - Default - If a group can start a conversation, they can reply.
  • Reply Limit for Conversation. - Default - If a group can start a conversation, the reply limit is disabled (ie infinite).
  • Manage Conversations by anyone. - Default - If a group can edit any conversation posts, this permission is set for them.
Manual post-installation steps - Rebuild Search Index
The add-on will report (via server errors) if conversation related content types require re-indexing.
Performance impact
  • 1 extra query per conversation message posted due to indexing, and indexing itself.
Contributing features or bug fixes
Please create a Github Pull request via the "More Information" link.
Télécharger Version xenforo 2.0 :
V2.0.8 - Bugfix : Compatibility update for Conversation Essentials v2.1.0+
V2.0.9 - php 7.4 compatibility : php 7.4 compatibility update (Requires XF v2.1.3)
V2.1.0 - Maintenance : Require XF2.1+, remove XF2.0 support.
Do not disclose conversation title history to conversation starter unless they explicitly have permission
V2.1.1 - Maintenance : When "Allow conversations with no one" is enabled, also allow users to explicitly start a conversation with their self
V2.1.2 - Bugfix : Fix that deleting a conversation did not remove history items.
On install, Cleanup xf_edit_history table of orphaned conversation entries.
Télécharger Version pour xenforo 2.1 :
Version 2.2.0 XF2 Compatibility update
Requires php 7.0+
Supports XF2.2
Version 2.2.1 Maintenance update : Remove unneeded SV/Utils bundle from redistributable, removing from hashes.json
Télécharger V2.2.1 :
Version 2.2.2 - Maintenance update :
Code style cleanup
Use strict equality checks
Télécharger V2.2.2 :
Version 2.3.0 - Maintenance update :
Require XenForo 2.2+
Improve handling of leaving/joining conversation and the impact on search.
This will require re-indexing conversation messages.
When a user joins a conversation, ensure they can search that conversation
If a user leaves a conversation, do not return it in search results.
Télécharger V2.3.0 :
Version 2.4.0 - Maintenance & bugfix update :
This add-on is now available on atelieraphelion.com
  • Require php 7.2+
  • Require Standard Library by Xon v1.18.0+
  • Require Search Improvements v2.9.0+
  • Fix viewing formatted conversation title history would not escape HTML
  • Fix edit history for a conversation's title was not deleted when the conversation was
  • Fix the 'Received by' search field only inspected active recipients
    • Requires re-indexing of conversations/conversation messages
    • Indexes recipients who can view a conversation and who where a member separately
Télécharger V2.4.0 :
Version 2.4.1 - Bugfix update : Fix SQL error when the last member of a conversation leaves.
Télécharger V2.4.1 :
Version 2.4.2 - Bugfix update :
- When using XenForo Enhanced Search:
Improve reliability of indexing recipients into conversations for search
Improve generating constraint restricting conversations to recipients
If using Search Improvements v2.9.6 or earlier, ensure the option "Push "View X by others" check into XFES" is enabled.
If it was disabled, you will need to re-index for conversation search to return results
Télécharger V2.4.2 :
Version 2.4.3 - Bugfix update :
- Fix mysql-based search support not returning conversation search results when using the conversation search tab.
Télécharger V2.4.3 :
Version 2.4.4 - Maintenance update :
- Require Search Improvements v2.10.0+
- Improve how conversations are filtered out of search results when using XFES without ElasticSearch Essentials.
Télécharger V2.4.4 :
Version 2.4.5 - Bugfix update : Fix edited conversation messages lacked the "Last edited:" marker after they had been edited.
Télécharger V2.4.5 :
Version 2.4.6 - Minor feature update :
- Add "silently edit" feature for editing conversation messages, requires the "edit any message" permission.
Télécharger V2.4.6 :
Version 2.5.0 - XenForo 2.3 support :
  • For XF2.2, require re-indexing of conversations & conversation messages!
  • Require StandardLib v1.21.0+
  • Require Search Improvements v2.16.0+
  • XF2.3 support
  • php 8.4+ compatibility fixes
  • Remove "Allow conversations with no one" option. XF2.3 supports this by default
Télécharger V2.5.0 :
Version 2.5.1 - Bugfix update :
  • Fix adding a recipient to a direct message would re-index the conversation twice with XF2.3
  • Fix check with XF2.2 for starting a conversation without recipients
Télécharger V2.5.1 :
Ajout de la version 2.2.1 :)
Ajout de la version 2.2.2 :)
Ajout de la version 2.3.0 :)
Ajout de la version 2.4.0 :)
Ajout de la version 2.4.1 :)
Ajout de la version 2.4.3 :)
Ajout de la version 2.4.4 :)
Ajout de la version 2.4.5 :)
Ajout de la version 2.4.6 :)
Ajout de la version 2.5.1 :)
