FEATURES
EXAMPLES in screens
< visitor tabs and search tab in top navigation >
... with a few example links with icons
< visitor tabs only in top navigation, search tab in main navigation >
Plus de details ici : [cXF] Top Navigation
Télécharger V1.6.4 :
Version 1.6.5 :
Maintenance update
minor updates to option descriptions, fixed typos if any and other minor maintenance stuff
no new features or bug fixes in this update.
Télécharger V1.6.5 :
Version 1.6.6 : added rel="noopener" to links that open in new tab
Version 1.6.7 : compatibility with [cXF] Thread scroll enhancement add-on for XF 2.2
Version 1.7.0 :
bugfix for login and register icons if the field for the icon in style properties is blank
visitor panel adjustments for XenForo 2.2
*probably you will need to merge templates after upgrading
Version 1.7.1 : bugfix: fix for alerts badge if using visitor tabs in top navigation (for XF 2.2 only)
Télécharger V1.7.1 :
Version 1.7.2 : increased the z-index (XF2.2)
Version 1.7.3 : due to
Télécharger V1.7.3 :
Version 1.7.4 :
changed the PHP file with different approach for tabbed options
option tabs are all phrased now
*the
Télécharger V1.7.4 :
Version 1.7.5 Bigfix : updated the event listener to fix an issue on the "Advertising" and "Notices" page in XenForo
Télécharger V1.7.5 :
Version 1.7.6 : bugfix for phrase in Options for top link
Version 1.7.7 :
added the title attribute for user avatar
changed the aria-label phrase from inbox to conversations
Version 1.8.0 : added permissions for Top links
Important : Make sure to set permissions to Yes, to view the top links. You can set them for groups or individuals.
Télécharger V1.8.0 :
Version 1.9.0 : added option to show tooltip for top links
Télécharger V1.9.0 :
Version 1.9.1 :
- removed code required for [cXF] Staff Menu add-on (code is added as template modification in that add-on)
- LESS template optimization for thread view types
Télécharger V1.9.1 :
Version 1.9.2 :
- added support for DragonByte eCommerce and DragonByte Credits add-on: now you can show icons from this add-on next to Alerts tab* in Top Navigation.
*make sure to set in the DragonByte Credits add-on option page the Navbar Tab to show After "Alerts" Tab.
Télécharger V1.9.2 :
Version 1.9.3 : bugfix for template modification.
Télécharger V1.9.3 :
Version 1.9.4 : compatibility fix with [DBTech] DragonByte eCommerce version 3.3.0
Télécharger V1.9.4 :
Version 1.9.5 : compatibility fix for XenForo 2.3
Télécharger V1.9.5 :
Version 19.6 : Bugfix for phrase in direct message menu (XF 2.3 only)
Télécharger V1.9.6 :
- sticky or don't sticky top navigation to the top of your forum (separate option for mobile view)
- move elements to top navigation: Visitor Tabs only, Search Tab only, Visitor Tabs AND Search tab
- and up to 10 links to top navigation (title, URL, open in new tab, open in an overlay, link icon)
- top links can have a drop-down menu with up to 5 custom links
- option to add custom code to top menu
- adjustable menu width for each menu separately
- add an icon for login and register button
- custom menu (optional you can manually add Mega Menu (DIY tutorial for our customers on our site here))
EXAMPLES in screens
Version 1.6.5 :
Maintenance update
Version 1.7.0 :
z-index
increase for sticky top navigation, the z-index
has been increased for main sticky navigationTélécharger V1.7.3 :
Version 1.7.4 :
*the
MacroRender.php
file can be deleted from serverTélécharger V1.7.4 :
Version 1.7.7 :
Version 1.9.1 :
Version 1.9.2 :
