[TH] iO Dark Mode 2.1.3.0.1 a 2.3.4.0.0
Style [TH] iO Dark Mode 2.1.3.0.1 a 2.3.4.0.0
Titre du sujet Titre du sujet [TH] iO Dark Mode 2.1.3.0.1 a 2.3.4.0.0
Réponses Réponses 18
Affichages Affichages 1 487
iO Dark Mode
Create a dynamic forum with this minimalist, vibrant dark theme. With concepts from Apple’s Human Interface Guidelines, your forum will be sleek and captivating. Make iO unique with category strips that automatically change color based on your primary brand color.
  • Built with the UI.X 2 framework
  • Clean typography
  • Uses material line icons
  • Full page animations on page load
  • Uses a tab bar at the bottom of the screen on mobile devices
  • Full height iOS-style modals
  • Category strips that automatically change color based on your primary brand color
Looking for a light version?
Click here to check out iO.
Télécharger V 2.1.3.0 :
Bugs fixed : Réactivation des dégradés de catégorie intelligents
Télécharger V 2.1.3.1 :
Version 2 2.1.4.0 Changelog :
  • XenForo 2.1.4 compatibility
For more information: https://github.com/Audentio/xf2theme-issues/milestone/32?closed=1
Note : This release cannot be used on XenForo 2.0, it is exclusively for XenForo 2.1 only.
Télécharger V 2.1.4.0 :
Version 2.1.4.1.0 :
Télécharger V2.1.4.1.0 :
Version 2.1.5.0.0 Changelog :
XenForo 2.1.5 compatibility
Télécharger V2.1.5.0.0 :
Version 2.1.6.0.0 :
Télécharger V2.1.6.0.0 :
Version 2.1.7.0.0 Changelog :
XenForo 2.1.7 compatibility
Télécharger V2.1.7.0.0 :
Version 2.1.8.1.0 changelog :
Télécharger V2.1.8.1.0 :
Version 2.1.10.0.0 Changelog :
XenForo 2.1.10.0.0 compatibility
Improved footer widget styling
Fixed an issue with tooltip arrow styling
Improved discussion list coloring properties which now allow you to color both even/odd colors
Télécharger V2.1.10.0.0 :
Version 2.2.0.0.0 Released Changelog :
XenForo 2.2.0 compatibility
Many more issues and enhancements were also added to this update which can also be viewed here.
Note : This update does require a UI.X add-on update to function properly.
Version 2.2.0.2.0 Released :
Version 2.2.1.0.0 Released
Télécharger V2.2.1.0.0 :
Version 2.2.2.0.0 Released :
Télécharger V2.2.2.0.0 :
Version 2.2.2.1.0 Released :
Télécharger V2.2.2.1.0 :
Version 2.2.3.0.0 Changlog :
Fixed an issue that caused nodes to disappear when upgrading to the last update.
Fixed JS packaging issues
Télécharger V2.2.3.0.0 :
Version 2.2.3.1.0 Changelog :
Version 2.2.4.0.0 Changelog :
XenForo 2.2.4 compatibility
Added a feature that wraps the nav phrase in span for additional design options with the sidebar navigation
Fixed an issue on Legend that caused the login phrase to not be viewable on mobile
Fixed an issue that caused meta titles to not work properly
Fixed an issue with the overlay blur effect that caused page width issues on mobile when modals are opened
Fixed an issue with the Fab button which caused it to show above the text input area on mobile devices
Fixed an issue that caused the sticky tab bar to cover the entire screen when scrolled past certain points with either infinite scroll addons or with header wrapper disabled
Fixed an issue with the style property known as drop-down menus (beta) which caused random jumping when hovering over navigation items
Fixed an issue with the search bar drop-down button "Advanced" which lost its color in the last update
Fixed a height issue with overflow category nodes
Télécharger V2.2.4.0.0 :
Version 2.2.5.0.0 Changelog :
XenForo 2.2.5 compatibility
Télécharger V2.2.5.0.0 :
Version 2.2.5.1.0 Changelog :
Télécharger V2.2.5.1.0 :
Version 2.2.6 Changelog :
XenForo 2.2.6 compatibility
Télécharger V2.2.6.0.0 :
Version 2.2.7.0.0 Changelog : XenForo 2.2.7 compatibility :
Note :
This release cannot be used on XenForo 2.1, it is exclusively for XenForo 2.2 only.
Télécharger V2.2.7.0.0 :
Version 2.2.8.1.0 Changelog :
XenForo 2.2.8 compatibility
Mobile usability fixes
Télécharger V2.2.8.1.0 :
Version 2.2.9.0.0 Changelog :
XenForo 2.2.9 compatibility
Version 2.2.10.0.0 Changelog :
XenForo 2.2.10 compatibility
Multiple bugfixes
Version 2.2.10.0.1 Changelog :
Fixes for some notification/message placement configurations causing them to be inaccessible
Other minor bugfixes
Télécharger V2.2.10.0.1 :
Version 2.2.12.0.0 Changelog :
- Updated compatibility with XenForo 2.2.12
Télécharger V2.2.12.0.0 :
Version 2.2.13.0.0 Changelog :
Updated compatibility with XenForo 2.2.13
Version 2.2.13.0.1 Changelog :
Minor update to properly hide JS back button on standard rendering methods
Télécharger V2.2.13.0.1 :
Version 2.2.13.0.2 Changelog :
Multiple optimizations and minor bugfixes
Télécharger V2.2.13.0.2 :
Version 2.3.4.0.0 Changelog :
Updated for XF 2.3.4.0.0
Note : This release cannot be used on XenForo 2.2, it is exclusively for XenForo 2.3 only.
Télécharger V2.3.4.0.0 :
Ajout de la version 2.1.4.0 :)
Ajout de la version 2.1.4.1.0 :)
Ajout de la version 2.1.6.0.0 :)
Ajout de la version 2.1.7.0.0 :)
Ajout de la version 2.1.8.1.0 :)
Ajout de la version 2.2.1.0.0 :)
Ajout de la version 2.2.2.1.0 :)
Ajout de la version 2.2.3.0.0 :)
Ajout de la version 2.2.4.0.0 :)
Ajout de la version 2.2.5.0.0 :)
Ajout de la version 2.2.6 :)
Ajout de la version 2.2.8.1.0 :)
Ajout de la version 2.2.12.0.0 :)
Ajout de la version 2.2.13.0.2 :)
Ajout de la version 2.3.4.0.0 :)
