This add-on allows you to properly handle GIF animations using
Adds a new option to ACP -->> Attachments
Télécharger V2.2.9 :
Version 2.2.10 Support for the profile cover : Added support for gif animations for the profile cover.
Télécharger V2.2.10 :
Version 2.3.6 : Update for xenforo 2.3
Télécharger V2.3.6 :
Version 2.3.6.1 :
Added compatibility of the forum version 2.2.6 and higher. The addon now works on both 2.2.* and 2.3.*
The gifsicle utility installation check is enabled. Verification is also enabled on a server running the Windows operating system.
New addon settings have been added: in the attachment block in the message, play the animation of GIF images. This can be disabled on slow servers. Added the ability to remove a notification about a missing gifsicle if the utility is installed, but the addon still shows the notification, possibly with incorrect verification.
The addon settings are displayed in a separate group.
Optimized the code
Télécharger V2.3.6.1 :
Version 2.3.6 Patch Level 1 : Fixed an issue with adding video/audio files.
Télécharger V2.3.6 Patch Level 1 :
Version 2.3.6 Patch Level 2 :
- The setting did not work when the installation of the utility was falsely triggered.
- Fixed the issue of false positive validation during installation on centos.
- Fixed a problem when determining the size of the avatar
Version 2.3.6 Patch Level 3 : Fixed a minor issue with checking the avatar size.
Télécharger V2.3.6 Patch Level 3 :
gifsicle, without Imagick PECL extension.Adds a new option to ACP -->> Attachments
Version 2.3.6.1 :
Optimized the code
