XenForo full Nulled
Some of the changes in XF 2.3.10 include:
Ensure "View Older Results" link appears on last page of search results
Ensure "No such recipient" bounce responses are classified as hard bounces
Ensure "Account Closed" bounce responses are classified as hard bounces
Ensure "Recipient not found" bounce responses are classified as hard bounces
Ensure "mailbox is disabled" bounce responses are classified as hard bounces
Ensure "not configured to receive" bounce responses are classified as hard bounces
Prevent inet_pton() ValueError when IP address contains null bytes
Use original Email object for error logging after DKIM signing to prevent undefined method error
Skip array values during custom field multiselect validation to prevent Array to string conversion warning
Normalize discouragement delay min/max values to prevent mt_rand() ValueError
Suppress dns_get_record() warning during DKIM verification to prevent job crash on DNS failure
Prevent alerts from being sent to banned users
Correct OAuth2 token revocation to properly invalidate both access and refresh tokens
Respect direction parameter for multi-column sort ordering in Finder
Re-enable passkey button when WebAuthn registration or authentication is aborted
Add missing bookmark_id index to xf_bookmark_label_use table
Prevent accumulating whitespace in GenerateFinders CLI command on repeated runs
Avoid exception-based flow control in getFinder for entity class resolution
Set explicit working directory for sub-processes to prevent failure when CWD is inaccessible
Prevent type error when custom field type changes with preserved values
Include purchasable ID in Stripe product and plan ID generation
does not round-trip after editing a post
Implement ContainableInterface and DatableInterface on various child content entities
Create template when generating a route with xf-make:route
à tous,
